enable mirror to port
            enable mirror to [port
                port | port-list
                port_list
                loopback-port
                port] {remote-tag
                tag}
        Description
      Dedicates a port on the switch to be the mirror output port, or the monitor port.
        Syntax Description
                            | port | Specifies the mirror output
                                port. |
                            | port_list | Specifies the list of ports
                                where traffic is to be mirrored. |
                            | loopback-port | Specifies an otherwise unused
                                port required when mirroring to a port_list. The
                                loopback-port is not available for switching user data
                                traffic. |
                            | port | Specifies a single loopback
                                port that is used internally to provide this feature. |
                            | remote-tag | Specifies the value of the
                                    VLAN ID used by the mirrored
                                packets when egressing the monitor port. |
        Usage Guidelines
            Port mirroring configures the switch to copy all traffic
                associated with one or more ports, VLANS or virtual ports. A virtual port is a
                combination of a VLAN and a port. The monitor port(s) can be connected to a network
                analyzer or RMON probe for packet analysis. The switch uses a traffic filter that
                copies a group of traffic to the monitor port.
            Up to 16 mirroring filters and up to four monitor ports can be
                configured on the switch. After a port has been specified as a monitor port, it
                cannot be used for any other function. Frames that contain errors are not
                mirrored.
             You cannot run ELSM and mirroring on the same port. If you
                attempt to enable mirroring on a port that is already enabled for ELSM, the switch
                returns a message similar to the following:
            Error: Port mirroring cannot be enabled on an ELSM enabled port.
        Standalone Switches and
                SummitStacks
            The traffic filter can be defined based on one of the following
                criteria:
                - Physical port—All data
                    that traverses the port, regardless of VLAN configuration, is copied to the
                    monitor port(s). You can specify which traffic the port mirrors:
                        - Ingress—Mirrors traffic received at the port.
- Egress—Mirrors traffic sent from the port.
                            Ingress and egress—Mirrors traffic either received
                                at the port or sent from the port. (If you omit the optional parameters, all traffic
                                is forwarded; the default for port-based mirroring is ingress and
                                egress).
-  VLAN—All data to a particular VLAN, regardless of the
                    physical port configuration, is copied to the monitor port.
- Virtual port—All data
                    specific to a VLAN on a specific port is copied to the monitor port.
- ExtremeSwitching series
                    switches support a maximum of 128 mirroring filters with the restriction that a
                    maximum of 16 VLAN and/or virtual port (port + VLAN) filters may be
                    configured.
- ExtremeXOS supports up to 16 monitor ports for one-to-many
                    mirroring.
- Only traffic ingressing a VLAN can be monitored; you cannot
                    specify ingressing or egressing traffic when mirroring VLAN traffic.
- Ingress traffic is mirrored as it is received (on the
                    wire).
- Packets which match both an ingress filter and an egress
                    filter will result in two packets egressing the monitor port or ports.
- In normal mirroring, a monitor port cannot be added to a
                    load share group. In one-to-many mirroring, a monitor port list can be added to
                    a load share group, but a loopback port cannot be used in a load share group.
- You can run mirroring and sFlow
                    on the same device when you are running ExtremeSwitching series
                    switches.
- With a monitor port or ports on
                        ExtremeSwitching series switches, all traffic ingressing the monitor
                    port or ports is tagged only if the ingress packet is tagged. If the packet
                    arrived at the ingress port as untagged, the packet egress the monitor port or
                    ports as untagged.
- Two packets are mirrored when a packet encounters both an
                    ingress and egress mirroring filter.
                    The configuration of remote-tag does not require the
                        creation of a VLAN with the same tag; on these platforms the existence of a
                        VLAN with the same tag as a configured remote-tag is prevented. This
                        combination is allowed so that an intermediate remote mirroring switch can
                        configure remote mirroring using the same remote mirroring tag as other
                        source switches in the network. Make sure that VLANs meant to carry normal
                        user traffic are not configured with a tag used for remote mirroring. When a VLAN is created with remote-tag, that tag is locked
                        and a normal VLAN cannot have that tag. The tag is unique across the switch.
                        Similarly if you try to create a remote-tag VLAN where remote-tag already
                        exists in a normal VLAN as a VLAN tag, you cannot use that tag and the VLAN
                        creation fails.
SummitStack Only
            following criteria:
                                egress).
                    particular VLAN, regardless of the physical port configuration, is copied to the
                    monitor port.
- SummitStack supports a maximum of 128 mirroring filters with
                    the restriction that a maximum of 16 VLAN and/or virtual port (port + VLAN)
                    filters may be configured.
                    mirroring.
                    wire).
- When traffic is modified by hardware on egress, egress
                    mirrored packets may not be transmitted out of the monitor port as they egressed
                    the port containing the egress mirroring filter. For example, an egress mirrored
                    packet that undergoes VLAN translation is mirrored with the untranslated VLAN
                    ID. In addition, IP multicast packets which are egress mirrored contain the
                    source MAC address and VLAN ID of the unmodified packet.
- You cannot include the monitor port for a SummitStack in a
                    load-sharing group.
- You can run mirroring and sFlow on the same device when you
                    are running a SummitStack.
- With a monitor port or ports, the mirrored packet is tagged
                    only if the ingress packet is tagged (regardless of what module the ingressing
                    port is on). If the packet arrived at the ingress port as untagged, the packet
                    egress the monitor port(s) as untagged.
- You may see a packet mirrored twice. This occurs only if
                    both the ingress mirrored port and the monitor port or ports are on the same
                    one-half of the module and the egress mirrored port is either on the other
                    one-half of that module or on another module.
- The configuration of remote-tag does not require the
                    creation of a VLAN with the same tag; on these platforms the existence of a VLAN
                    with the same tag as a configured remote-tag is prevented. This combination is
                    allowed so that an intermediate remote mirroring switch can configure remote
                    mirroring using the same remote mirroring tag as other source switches in the
                    network. Make sure that VLANs meant to carry normal user traffic are not
- When a VLAN is created with remote-tag, that tag is locked
                    Similarly if you try to create a remote-tag VLAN where remote-tag already exists
                    in a normal VLAN as a VLAN tag, you cannot use that tag and the VLAN creation
                    fails.
      The following example selects port 4 as the mirror, or monitor,
                port:
      # enable mirror to port 4
            This command was added in ExtremeXOS 15.3.
        Platform Availability
      This command is available on all Universal switches supported in
     this document.
